Changelog: version 2.2
Posted: 17 Nov 2016, 18:56
New icon and name for previous "Magic" tool which is now called "Sprayer" tool and does same thing (brush limited to first clicked color)
New paint brush tool icon
New paint tool "Magic wand" which replaces clicked color with new one
Imported palette is now limited to 32x32 pixels size (=up to 1024 colors)
New rotate on X/Y/Z axis functions in Voxel edit-mode
Reorganized Voxel functions in pop menus with submenus, new icons and better names
Optimized functions FlipX, FlipY and FlipZ for voxels (up to x8 times faster on big voxel models!)
New function to dig voxels inside blueprint
New function "Convert voxels to elements (cubes)" which create one element (cube) per voxel
Rotating model now also rotates voxels
New functions in Elements list to rotate selected elements on X, Y or Z
New "Rotate model on Z axis" function in "Edit" main menu
Modified functions names to Rotate model
Small optimization on creation of elements (also improves a bit conversions of voxels to elements)
"Optimize elements faces" and "Cull elements faces" are now undo-able
Optimizing elements faces now proposes to remove elements without face
Implemented new option in Preferences > Display > Emulate elements tint colors
New function "Remove unused textures" in Elements Material
Added new function "Rename texture" which edit texture label and update all elements using that texture with the new label
Old function "Rename" is now "Edit label" in Elements Material
Blueprint is now saved in .cubik format
Blueprint modifications are undo/redo-able
Added "UV snap size" option to Grid settings dialog (UV snap in UV editor now uses it instead of mouse snap size) and removed useless descriptions in grid settings dialog
Left shift works in Elements list
Small global optimizations
- Fixed bug with shadow in Preview edit-mode > Floor display setting which was rotated wrongly
- Fixed bug with missing default display presets
- Fixed bug with not loaded custom display presets
- Fixed bug with undo/redo of "Create atlas" functions in Elements Material
- Fixed bug with undo/redo of element faces properties modifications
- Fixed potential bug with undo/redo
- Default window focus state to true
- Fixed bug with gizmo remaining on screen in some case after Undo action
- Fixed bug: Mesh without texture (imported OBJ) wasn't able to be deleted or undone or voxelized
- Potentially fixed bug which was closing Cubik and opening Cubik temp folder after some random time
