Why i can not export in cubik studio 1.8 i will export pls
Posted: 03 Nov 2019, 20:23
by Mattix
Re: Why i can not export in cubik studio 1.8 i will export pls
Posted: 04 Nov 2019, 10:02
Cubik Pro is still available on the
Download page if you scroll down.
Posted: 04 Nov 2019, 12:02
by Mattix
HanFox wrote: ↑04 Nov 2019, 10:02
The problem is not the same, so it is not possible to export, save or use the 1.8, but it is always with the key yes you need an internet connection although I am connected; D and it in offline mode just not wants to export; /
Posted: 23 Jan 2020, 18:37
by Need_Not
Mattix wrote: ↑04 Nov 2019, 12:02
Yeah it's a common issue with modern windows 10 because I have tried it with over 5 computers and none of them worked + I've seen lots of other people with the issue, I my self don't play PvP as much so I don't mind but when I did I had to find a pack with 1.8 format then scale the model super big so I could see rotations better then I just by hand messed with the numbers till it worked!
