Page 1 of 2
Textures dont load ingame?
Posted: 16 Nov 2016, 15:31
by Codex
Hey,
I dont know why but if I export an json and then open it Ingame the GUI texture shows but if I place down the Block, it wont
Block used: red_nether_brick
Mc version: 1.10.2
And btw, if I use Voxels, I need the Voxelpalet in my Texturepack, right? And if yes, where can I find it?
Ty for the help ^^
Re: Textures dont load ingame?
Posted: 16 Nov 2016, 15:37
If you use voxels, you need to convert them to elements before exporting to Minecraft JSON.
After conversion you need to export to JSON and save the generated texture.
To save the generated texture, you have 2 ways:
- Save it manually: right click on texture > Save texture
- Always export texture aside Minecraft JSON: Go in Tools > Preferences > Formats > Save textures as png on export (aside json)
Posted: 16 Nov 2016, 15:41
by Codex
Omg thank you
Your answered so fast :ยง
Posted: 16 Nov 2016, 16:18
by Codex
Another short question, this ist the
http://hastebin.com/juyihenivo.json json file and the Problem is the Textures dont show up ingame, they are located in the textures/blocks
Any idea ?
Posted: 16 Nov 2016, 16:35
if "textures/blocks/SurgeyTable1.png" file and "blocks/wool_colored_cyan" exist in your RP your model should be textured.
Posted: 16 Nov 2016, 16:59
by Codex
They do but it still doesnt load... ;(
Posted: 16 Nov 2016, 17:55
For MC1.10 all files/folders in RPs have to be lowercase. i.e. you need to change SurgeyTable1.png to be called surgeytable1.png
Posted: 16 Nov 2016, 18:15
by Codex
Im sorry to annoy you, but im still stuck. So if it helps you in anyway, I can give you the resource Pack with the json (purpure_block i guess) And the textures etc, I used Mc 1.10.2
File:
http://www.mediafire.com/file/0j1edbfxe ... ckPack.zip
Posted: 16 Nov 2016, 18:40
I made a mistake when I said about filenames that was a change only implemented in MC1.11, but future proofing, hey?
Regardless, your model errors because it falls outside of the allowed range for MC (-16 to +32).
18:39:43] [Client thread/WARN]: Unable to load block model: 'minecraft:block/purpur_block' for variant: 'minecraft:purpur_block#normal': com.google.gson.JsonParseException: 'to' specifier exceeds the allowed boundaries: Vector3f[37.5, 13.0, 15.0]
[18:39:43] [Client thread/WARN]: Unable to load block model: 'minecraft:block/purpur_block' for variant: 'minecraft:purpur_double_slab#variant=default': com.google.gson.JsonParseException: 'to' specifier exceeds the allowed boundaries: Vector3f[37.5, 13.0, 15.0]
[18:39:43] [Client thread/WARN]: In parent chain: minecraft:item/purpur_block -> minecraft:block/purpur_block; unable to load model: 'minecraft:block/purpur_block'
That refers to:
"__comment": "Cube5",
"from": [ 18.5, 12, 1 ],
"to": [ 37.5, 13, 15 ],
"rotation": { "origin": [ 18.5, 12, 1 ], "axis": "z", "angle": 45 },
"faces": {
"down": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" },
"up": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" },
"north": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" },
"south": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" },
"east": { "uv": [ 0, 0, 16, 16 ], "texture": "#texture", "cullface": "east" }
Posted: 16 Nov 2016, 18:46
by Codex
Ohhhhhhhh, Thank you so much, im dumb
So I cant use all 3x3x3 Blocks ? So what exactly am I allowed to do ?
And yes future proofing
Good to know so I dont suffer on that in the futer ^^
But also Thank You for the answer!!
