The object its not the correct one
Posted: 01 May 2017, 12:01
by Dibujaman_
I have the problem of the item is not the same as the one done
And tried everything and it does not give me errors in the moment of exporting it
Instead of showing me the shield, it shows me a giant chest, but when I put it, the shield appears
(I tried exporting to 5 diferents items y blocks)
gold_block.json
(13.28 KiB) Downloaded 350 times
Re: The object its not the correct one
Posted: 01 May 2017, 12:18
You need to post a resourcepack of the issue. Otherwise all anyone can do is blindly guess.
Re: The object its not the correct one  [Solved]
Posted: 01 May 2017, 17:53
by Geenium
You need to remove the line: "parent": "builtin/entity", from the top of the file.
