3d Mobs/Entities?! [Please Help]
Posted: 19 Apr 2017, 20:29
by MinerYT
So Recently I saw a video by "FizzyChicken" or two actually which showcase changing entities into a different look (with a resourcepack). I saw in Cubik a "jpm" if thats the right thing where do I put the file in? (Also I know thats its optifine)..
-MinerYT
Re: 3d Mobs/Entities?! [Please Help]
Posted: 20 Apr 2017, 01:43
by PanicPenguin
You can but you need optifine, although I made many mobs using item durability, a plugin, and animation. The problem with this is with the plugin, it is possible with MythicMobs but it is very hard to configure.
Posted: 20 Apr 2017, 13:28
by MinerYT
PanicPenguin wrote: 20 Apr 2017, 01:43
I know durabilities but how did you do custom mobs(with a resource pack).. and what file do you put it in
Posted: 26 Apr 2017, 19:57
by CaptainGalax
MinerYT wrote: 20 Apr 2017, 13:28
https://www.youtube.com/watch?v=tU5aWbkLTNY
Posted: 29 Apr 2017, 14:23
by MinerYT
CaptainGalax wrote: 26 Apr 2017, 19:57
It's in another language....
Re: 3d Mobs/Entities?! [Please Help] [Solved]
Posted: 08 May 2017, 13:54
To create 3D models for entities, you can use Cubik (for modeling) and Optifine (for rendering in game).
Cubik only export JPM files which are basically a 3D model to be used as a "bone".
Optifine needs JEM + JPM(s). JEM defines how an entity is built. It's in this file that you can "link" different JPM files to attach models to the different bones of the entity.
A "bone" can be anything composing the body of the entity (head, legs, arms, torso, etc).
I invite you then to read the Optifine JEM and JPM description. They are JSON and thanks to Cubik you just need to learn JEM format.
Documentation here:
https://github.com/sp614x/optifine/tree ... ineDoc/doc
