Page 1 of 2
Item getting darking if your looking up
Posted: 03 Nov 2016, 06:16
by epicskymi
Anyone know why this is happening? the item gets darker the higher your cursor is
Looking down
Looking up
Also why doesn't cubik studio save preview settings?
Re: Item getting darking if your looking up
Posted: 03 Nov 2016, 07:44
You can fix the darker light (which is a bug in Minecraft) by disabling shading on all elements (you can do that in elements manager).
What do you mean by not saved display settings? In .cubik format?
Posted: 03 Nov 2016, 08:30
by epicskymi
ye I save the project in .cubik but when I reopen it all the display settings are default again
Posted: 03 Nov 2016, 08:41
by epicskymi
Also "shade": false, in the json file its still happening
Posted: 03 Nov 2016, 17:00
by epicskymi
I should add this is using damage models for a diamond hoe if that helps solve this issue
Posted: 03 Nov 2016, 17:07
This is probably a bug (or a missing implementation)
Posted: 04 Nov 2016, 04:38
by epicskymi
Ye idono why its doing this light to dark issue Iv disabled shading and it still happens :/
Posted: 04 Nov 2016, 08:12
by Vexilius
Make sure to turn Ambient Occlusion in the model to false.
I'm not going to guarantee results, but you never know.
Posted: 04 Nov 2016, 15:02
by epicskymi
Ill try that when I find the setting
Posted: 05 Nov 2016, 16:33
by epicskymi
Just tested disabling Ambient Occlusion nothing changed still doing the same thing
