.obj import
Posted: 07 Feb 2017, 09:21
by TolgaB93
Hello , First of all sorry for my bad english.
I am trying to import .obj file, when i tried in old version of cubik, it was asking for resolution setting (x16 x32 x64) and importing when time passes for a while.
Then I updated my cubic studio version to 0.64, now it's importing .obj file instantly but not asking for resolution and it don't creating any element. When I am trying go save as .json file, it says "no element found, you need do voxelization"
I really need tutorial video about importing .obj file in 0.64 . I think, I am doing somethink wrong, please help.
Re: .obj import [Solved]
Posted: 07 Feb 2017, 16:19
Cubik Pro was directly voxelizing import OBJ files (without keeping textures/colors).
Cubik Studio works differently. Cubik Studio can deal with meshes, primitives, voxels and elements (at the same time if needed). So after importing a OBJ, you must convert that OBJ to voxels (that when you select resolution). The voxelization process will keep colors. After voxelization, you'll have to convert voxels to elements. Then you'll be able to export to JSON format
Re: .obj import
Posted: 07 Feb 2017, 21:06
by TolgaB93
"after importing a OBJ, you must convert that OBJ to voxels (that when you select resolution). The voxelization process will keep colors. After voxelization, you'll have to convert voxels to elements. Then you'll be able to export to JSON format
Thank you but , I still didn't find how to convert voxels... It's very hard to use.
I didn't find any tutorial, which buttons do i need to press? Can you explain please ? Thank you mr admin.
Re: .obj import
Posted: 08 Feb 2017, 19:44
In mesh edit-mode : click "..." and then convert to voxels
In voxel edit-mode : click "..." and then convert to elements
Re: .obj import
Posted: 11 Feb 2017, 11:21
by TolgaB93
Thank you I finally did it .D:
1 final question.
I can't choose multiple element when clicking to model with Shift + L click. Or with any combination.
I am trying to choose 20 30 element of car tire at the same time. Is there any shortcut or easy way? Thanks.
Re: .obj import
Posted: 13 Feb 2017, 09:11
You can select multiple elements with right Shift or rift Ctrl or with elements list
Re: .obj import
Posted: 17 Mar 2017, 14:49
by TolgaB93
Hello again..
Is there a way to import obj file textures? Or do i have to paint by myself?
Re: .obj import
Posted: 17 Mar 2017, 21:36
by CaptainGalax
TolgaB93 wrote: 17 Mar 2017, 14:49
Hello again..
Use a MATERIAL (.mtl) file with a map_KD and texture coordinates
Re: .obj import
Posted: 12 Nov 2020, 18:39
by HyperBeast
When I try to import a .mtl file it says that cubik studio can't read it
