How to enlarge base area?
Posted: 31 Jan 2017, 02:48
by Jamesb013
Is there a way to make the base underneath and around your model bigger? and if so how because I wish to create larger models and my cubes are outside of the bounds im given. The current size I have now is a 3x3 thats 16x16 pixels big each square. Help!!
Re: How to enlarge base area?
Posted: 31 Jan 2017, 08:52
by AGearBeast
You can change the grid size under Views
Posted: 02 Feb 2017, 15:47
If you want to create models for Minecraft, then you are limited to the 3x3x3 zones. But in these zones, you can create your model at any scale you want and then use the display settings to rescale it smaller or bigger when attached to an entity (armor stand or mob)
