Armor stand shade problem when underground
Posted: 21 Jan 2017, 21:58
by CptJackSwagg3r
Hello guys! using the display settings under preview ive been trying to elevate items higher when its on an armor stands head >
http://imgur.com/a/ZafTy
but i have ran into one problem, when the armor stand is below ground the item gets very shaded >
http://imgur.com/a/qaqE1
Re: Armor stand shade problem when underground
Posted: 22 Jan 2017, 09:55
by weshuiz13
i think i understand your point of view
but there are a few problem
- first of all this bug is out of hands for the cubik team becuse the bug lays in the game it self mojang is reposeble for this not cubik
- reporting this to mojang using the bug tracker would not solve your problem aswell mojang is already aware of this problem but are not able or want to fix this bug
- if you want to fix this so badly try make the armour stand stand on a light source for example glowstone / sea lantern
Re: Armor stand shade problem when underground [Solved]
Posted: 22 Jan 2017, 19:18
by FistoF
It's not a bug. Ofc it turns dark while underground.
You can turns your armor stand invisible with /summon ArmorStand ~ ~ ~ {Invisible:1} or /summon armor_stand ~ ~ ~ {Invisible:1b,Invulnerable:1b,NoGravity:1b}
Posted: 23 Jan 2017, 10:19
Better to use invisible armor stands than hidden ones
Posted: 24 Jan 2017, 05:58
by CptJackSwagg3r
FistoF wrote: 22 Jan 2017, 19:18
i have tried this, still shade problem
Posted: 24 Jan 2017, 17:03
armor stand applies shade to all models attached to it and shade value comes from the block the armorstand is in. If your armor stand is in darkness, then all models attached to it will look dark.
Posted: 24 Jan 2017, 18:39
by weshuiz13
as i said already try make the armourstand placed on glowstone for example this will fix it or make it inviceble
Posted: 26 Jan 2017, 14:46
by CptJackSwagg3r
weshuiz13 wrote: 24 Jan 2017, 18:39
I have figured out a solution similar to yours, thank your for your input
Posted: 31 Jan 2017, 18:50
by weshuiz13
glad i could help
