Bugs and Feature Requests
Posted: 02 Nov 2016, 21:02
After working with the program a bit, I put together this list of bugs I've encountered and things I'd like to see added to Cubik Studio.
Feature requests:
Feature requests:
- Importing png files as layers, for quick model creation (I would use this by far more than any other single feature in the program)
- Changeable 3D workspace BG color
- Arrow key movement in the UV mapping screen
- Copy/pasting between UV map direction windows
- Plain color (non-textured) element view for Up/West/South viewports (textured view blends in with image backgrounds)
- Text tooltips when you hover over buttons. It would make the program much easier to learn.
- Custom keybinds (and a shortcut for viewing element color)
- Separate grid sizes for 3D workspace and UV mapping. I've found myself switching grid sizes a good deal when working with models larger than 1 block
- Delete backgrounds doesn't work
- Clicking on the menu bar again doesn't close the menu you've opened
- Keyboard shortcuts sometimes don't work until you click in the view window
- Undo screws up element texture views
- Hide/show elements applies to all existing elements, not just what you have selected
- Avoid bleeding edges by modifying UV mapping doesn't seem to work correctly.
Example:
