How to: Import .bdc3D/.bdc files into CubikStudio
Posted: 02 Nov 2016, 16:47
As you might have already noticed CubikStudio isn't able to import the .bdc3D and .bdc files (so far).
To import your old models you still have to have BDcraft Cubik Pro installed.
6 steps to get your old saves imported to CubikStudio:
I hope this helped you!. And maybe CubikStudio will be able to import the old files sometime.
Feel free to ask and give feedback
- Open BDcraft Cubik Pro and go to File > Open
- Select the .bdc3D/.bdc file and hit Open
- Check if everything is fine with the model and navigate to File > Export
- Export the model as .json (.obj works too but it may loose information) and close BDcraft Cubik Pro
- Open up CubikStudio and go to File > Import
- Navigate to your .json file you exportet before and hit Open
