How to Rotate Elements
Posted: 01 Dec 2016, 23:34
Hey there!
I'm trying to make a crate. I just did 1 of the 6 faces, planning on copying and pasting for the other 5. I have the face done, I'm happy with it, I converted the voxels to elements and now I'm stuck. Whenever I copy and paste the elements, I can only rotate them 45 degrees, not allowing me to actually build the cube that the crate needs to be. If I save as an OBJ and import as a mesh, then turn that mesh into voxels, I lose a lot of the details that I put on there, essentially meaning I'd have to make the whole thing by hand
I'm sure there's a very simple way to rotate CERTAIN elements 90 degrees (rather than everything in the viewport) via the Edit button or gizmo that I'm missing. Any helps is appreciated!
Below I've attached the 1 face I want to use for all faces, and my attempts at trying to copy/paste the elements. Thanks!
