see through block when the table i made is next to it
Posted: 29 Nov 2016, 15:46
by Shelly_Marsh
does anyone know how to fix the problem I am having with my table when i place the table i can see through block when that it is placed next to
link to an example image http://imgur.com/gallery/VJIMz
and here is the JSON file of the model
birch_planks.json.zip
(810 Bytes) Downloaded 423 times
Re: see through block when the table i made is next to it  [Solved]
Posted: 29 Nov 2016, 15:48
This is due to other blocks culling their faces when your block is placed next to them.
You either need to change your table to a transparent block that doesn't effect other blocks' culling (i.e. glass) or change your model to fill each side so you can't see through it.
