Make elements able to be rotated full 360 degrees (by applying transformations for each 90 degree increment.)
Posted: 25 Nov 2016, 02:38
Edit mode: Element
Right now you can only rotate 90 degrees in 22.5-degree increments, so if someone wants to rotate something, first they would have to rotate it via the transform function in the elements tab and then rotate it.
It would be much simpler on a per element basis to just rotate full 360 and have Cubik do the 90-degree transformations automatically.
