Import structure files
Posted: 23 Nov 2016, 12:13
by Geenium
Extension: .nbt
Format name: Minecraft structure file
Used by: Minecraft
Specs: Structure file format, NBT format info:
Info 1 Info 2
Format description:
Structure files are created by Minecraft from use of structure blocks.
Re: Import structure files
Posted: 23 Nov 2016, 20:38
That is interesting but the import would be limited to blocks.
Is that what you have in mind?
Why would it be useful as import?
Posted: 23 Nov 2016, 22:44
by Geenium
Yeah, just blocks would be fine.
As for why it would be useful, although structure blocks have a limited size they can save, it would cut out the need for exporting a schematic file from mcedit for builds that fit into a 32 x 32 x 32 cube. It would allow people to use Minecraft as a voxel tool without the need for mcedit as an intermediary program.
Posted: 23 Nov 2016, 23:36
ok, added to the todolist
A tutorial to create Minecraft structures and then import them in Cubik would be welcome however (via schematics for the moment)
Re: Import structure files [Solved]
Posted: 21 Jun 2017, 16:36
Done in 2.8 (with wool colors and planks support)
