Changelog: version 2.3
Posted: 21 Nov 2016, 15:49
This is not a mandatory update but contains a lot of new features that will be a must have for most users such as Copy/Paste, Clone meshes and PNG exporter!
New features and improvements:
Bugs:
Implemented Cut/Copy/Paste functions in Edit menu (Ctrl+X, Ctrl+C, Ctrl+V) to copy elements&meshes
Implemented Clone (Alt+left click) on multiple elements AND/OR multiple meshes/primitives
Buttons in "Selection" panel are now enabled/disabled depending on selected objects
Moved Reset and Delete options from "Element" menu to "Edit" menu
Updated limit of translation in Preview edit-mode to -80/+80
New Cut/Copy/Paste functions also work when only Blueprint is selected to cut/copy/paste voxels
Replaced Voxel "Saw" tool by "Laser" which can now paint (and not just cut)
Modified Undo/Redo labels for Voxel tools
New voxel function to clear voxels (without resetting settings)
New voxel functions to flip X/Y/Z voxels inside blueprint
OBJ material colors are now imported
New mesh tool to tint selection with selected color
Improved mesh tool to make selected meshes fit middle zone
Added Undo/Redo to Mesh function "Add custom mesh"
Voxelization is a bit more accurate (but a bit slower)
Voxelization should now work with textures on submeshes
Added 3 primitives (Slope, Corner-in, Corner-out)
.cubik format supports meshes with multiple textures
.cubik format supports meshes with colored materials (and multiple colors)
Exporting to PNG do not use elements color anymore (even if elements color is enabled in Preferences)
Added PNG properties in Model settings Dialog
PNG export can now be "GUI preview" (512x512) or "Main view" (1920x1080)
Moved PNG Anti-aliasing option from Preferences to Model settings
Undo/Redo now keep selection
Selection is saved in .cubik format
Replaced all Paomedia icons by Icons8 icons
Small optimization on various commands
Modified messages when a new version is available
Added Aiden in credits
Improved readability of checkbox and radio buttons on hidpi screens
PNG exporter do not render gizmos anymore
Modified delete confirm message
Refactoring
- Fixed bug with transparent textures which was not displayed correctly on elements
- Fixed bug which prevented loading Display presets in Preview edit-mode
- Fixed bug with Undo/Redo of voxelization function
- Saving to .cubik format now keep elements order
- Fixed bug with undo/redo and meshes using multiple textures
- Bug with bleeding voxels after voxelization should happen a lot less (but can't be really fixed without slowing down too much voxelization process)
- Fixed bug with inconsistent behavior depending on used tool when using semi-transparency color on voxels
- Fixed bug with CubikUpdater not found after update because path was parent
- Fixed bug with CubikStudio exiting when clicking on Update even if CubikUpdater was not found
- Fixed rare bug with .cubik Importer
- Fixed bug with custom Presets which was impossible to delete
- Fixed bug with loading blueprint from .cubik format
- Fixed bug with "Laser" tool when deleting
- Fixed bug with loading meshes and primitives rotations
