Model Splitting
Model Splitting
Post by JTK222 » 20 Nov 2016, 19:28
Option name: Split into smaller Models
Option type: Checkbox
Option action when enabled/disabled/clicked:
enabled: splits model to smaller 1block models on export
disabled: would not modify model export
JTK222
Re: Model Splitting
Post by Sphax » 20 Nov 2016, 20:58
Why do you need to save each element as separated models?
Re: Model Splitting
Post by JTK222 » 21 Nov 2016, 06:28
Not each element but it may be useful when you have a 1x2x1 Model (size in Blocks) split up into 2 1x1x1 Models.
As for example when you make a mod with a 2 Block height block you might need 2 Blocks for that and 1 of them would need to have an "empty"/"invisible" model.
Generally all 2 block tall minecraft blocks are split into 2 models see the tall flowers.
JTK222
Re: Model Splitting
Post by Sphax » 21 Nov 2016, 09:10
I see. That will need to wait the groups feature then. ;)
