OBJ Not Importing Correctly
Posted: 15 Mar 2021, 20:22
When I attempt to import my model from Blender, the texture was completely incorrect, and when I switched out the texture to the correct one, the mapping was completely wrong. Is there some way I can import the UV map and the texture correctly for my model? I have exported a UV map from Blender but I don't know how to use it for this.
This is the file, when I tried to upload it here it was not working, so I used Filebin: (This link expires in 1 week, ask me if you need a new one)
https://filebin.net/f8gn0v6vh31m4w3g/Fi ... t=dg3le2l4
When imported When converted to an element and correct texture applied, but with incorrect UV mapping: What it should look like (from Blender):
