A new section where you can create animations by means of animated textures.
Here's how I see it in practice :
Then see the following ideas and functions:
- New editing function model: "Animation"
- By pressing the temporary panel appears on the "Animation"
- Control functions on a temporary panel
- Here we show the objects that you animate
- Immediately after their objects are visible texture units
And now the time panel functions
- Button to add a new object to animate
- Delete button animation object
- go to the right button
- Button and change the selection of objects visibility blocks, respectively, attached to the line object
- Button to add the object block visibility
- Button to add a smooth transition for the object blocks visibility
- go to the left button
Sorry for my terrible English ...
I'm using a translator...
