Can't open Cubikstudio win64 [Solved]
Posted: 04 Nov 2020, 15:40
by SnoopyDodo
Hello,
I currently have a problem. When the Cubik update is done, I cannot access cubikstudio. I run cubikstudio, I cannot use it but the icon is in the taskbar...
I am under Win64. Anyone know how to fix this?
Thanks
Re: Can't open Cubikstudio win64
Posted: 07 Nov 2020, 15:18
Posted: 11 Nov 2020, 00:08
by SnoopyDodo
Even with an update nothing changes
Posted: 11 Nov 2020, 11:35
You can try each of these to see if it helps:
- Whilst the program is open select it in the taskbar then press Windows key + an arrow key
- Whilst the program is open select it in the taskbar and press Alt+Space and select "Maximize" from the menu that should appear in the top left of your screen
- Go to C:\Users\<user>\AppData\LocalLow\BDcraft\Cubik and edit cubikdata.json so that "windowX" and "windowY" are 0
Posted: 11 Nov 2020, 13:28
by SnoopyDodo
HanFox wrote: 11 Nov 2020, 11:35
The last solution worked
Many thanks !
