Can't launch Cubik Studio on Mac
Posted: 19 Nov 2016, 13:04
by katango
OSX says, "The application "CubikUpdater.app" can't be opened"
Re: >:( Cubik Studio for Mac is not working. [Solved]
Posted: 19 Nov 2016, 13:09
by katango
Solved!
On terminal:
chmod +x CubikUpdater.app/Contents/MacOS/CubikUpdater
Posted: 19 Nov 2016, 16:40
That's weird you had to do that... During our tests, only Linux need to do something like that to launch CubikUpdater. CubikUpdater was working straight out of the box.
Glad you figured how to solve the issue though.
Posted: 10 Jan 2017, 18:55
by Creepinson
katango wrote: 19 Nov 2016, 13:09
Solved!
On terminal:
THANK YOU!
Re: Can't launch Cubik Studio on Mac
Posted: 22 Mar 2019, 13:41
by spapadim
Apologies for necropost (not sure if I should have started new thread..).
In any case, I encountered
exact same behavior right now (two years later), and figured out how to replicate.
It seems the issue occurs only if you unzip via terminal, rather than via Finder (in which case, you probably know enough to chmod
). I unzipped (and then renamed .app dir) once with "unzip cubik_updater_macos.zip" via terminal and again by double-clicking zipfile in Finder, and then I get:
garfield:~/Downloads$ ls -l CubikUpdater-unzip.app/Contents/MacOS/CubikUpdater CubikUpdater-finder.app/Contents/MacOS/CubikUpdater
-rwxr-xr-x@ 1 spapadim staff 58709020 Nov 24 2016 CubikUpdater-finder.app/Contents/MacOS/CubikUpdater
-rw-r--r--@ 1 spapadim staff 58709020 Nov 24 2016 CubikUpdater-unzip.app/Contents/MacOS/CubikUpdater
No idea why unzip behaves this way, never noticed something like that before (weird indeed). But, mystery solved!
