Unable to activate Animaker
Posted: 20 Mar 2019, 16:15
by Tetsune
I got it to work once, but I haven't been able to since. I open it up and it makes me reactivate.
It gives me the following error when I try to activate:
http://prntscr.com/n0kqgv
Obviously, I'm connected to the internet.
When I press "Cancel" it seems to work, but when I reload it it makes me reactivate.
Re: Unable to activate Animaker  [Solved]
Posted: 21 Mar 2019, 04:38
Animaker is no longer an actively supported piece of software. If it has oddities they may never be fixed.
Make sure your system clock is set correctly, and if you use a proxy make sure proxy settings are set correctly system wide.
