Function: Change all faces  [Solved]
Post by Cookiesnom » 14 Nov 2016, 05:43
Edit mode: Element :element:
Function name: change all
I use cubik to animate my models and you have to go through a whole process to change the textures of one element.
For example, to change all the textures on an element it takes about 8 steps
But if you add a simple button e.g.
Then it would only take 3 steps
This wouldn't not only be helpful for me but would help in general for others that need to change all the faces of one object over and over.
Thank you for reading :)
Cookiesnom
Re: Function suggestion:Change all faces  [Solved]
Post by Sphax » 14 Nov 2016, 10:03
Right click on a texture in Elements Material and select apply to selection
= it already exist ;)
Re: Function: Change all faces
Post by Cookiesnom » 15 Nov 2016, 00:07
ohhhhhhhhh, thanks :)
Cookiesnom
