Add Button for hiding the key
Posted: 02 Nov 2016, 02:19
by Fabian9799
Can you add a button that hides the Serial key. Its very bad if i show someone the page and he sees the key :)
Re: Add Button for hiding the key
Posted: 02 Nov 2016, 13:13
by Zaliku
I believe you are the only one who can see it. Unless someone uses you/you use someones PC - then he/she is able to view it...
Posted: 02 Nov 2016, 17:54
Fabian9799 wrote: 02 Nov 2016, 02:19 Can you add a button that hides the Serial key. Its very bad if i show someone the page and he sees the key :)
If you mean on website, the key is visible only if you are logged in. We'll think on a way to partially hide keys by still allowing copy with selection.
Re: Add Button for hiding the key  [Solved]
Posted: 03 Nov 2016, 14:15
This is now implemented.
