I've bought Cubik for this one feature - to be able to make voxel models, then convert them to primitives and export in .java to use them in my 1.7.10 minecraft mods. However it didn't work right (you know what the problem is - rotation and position of the models are completely off) and I continued making models in Techne. I've been lurking on this forum for nearly a year to see if you fix this problem. And you still haven't even in 2.9.
So could you please fix it for real? I'm sure I'm not the only one who wants this to be fixed.
Fix the damn .java exporter already
Re: Fix the damn .java exporter already
This is a known issue and it's on the todolist. I'm very sorry for the delay on that fix, 2.9 should have improved that but, looks like that's not always the case depending on the model complexity.
I also need exporting to java... When it will be fixed ?
