Please help me, I am very anxious!Questions about JPM model textures.
Posted: 06 Aug 2018, 05:13
by jiri2
The model I made in Cubik is fine, but there is a problem with the textures imported into Minecraft.
The model in Cubik is like this:
But after importing Minecraft, it looks like this:
Please help me, I am really anxious!
Re: Please help me, I am very anxious!Questions about JPM model textures.
Posted: 09 Aug 2018, 00:34
by qqq5715715
me too export to mcpe often failed
Posted: 11 Aug 2018, 09:06
by RiCkYB_667
Hi there!
Is you voxel model totally filled before exporting to elements? Only 1 empty voxelspace inside can make strange things to happen ingame.
Anyway these are the steps i do for an export into Minecraft:
- Make sure the model is filled properly with Voxel menu->Transform->Fill volume (if its doing strange things, check for "holes" in your model)
- Convert voxels to elements using Atlas method
- On the Element toolbar click remove hidden faces and apply new culling (The 2 icons with the lightning)
- Right click voxel_atlas texture and rename it as needed, than save it to the textures folder accordingly.
- Export your model into the model folder
Try these steps if you haven't already, and let us know if it was any help!
Cheers!
