New voxel to Element funtion
Posted: 11 Nov 2016, 13:12
by Shelly_Marsh
Does anyone know how to use the new "Convert voxels to elements" function which generates an atlas for a lot less elements but bigger texture
Re: New voxel to Element funtion
Posted: 11 Nov 2016, 14:24
by Profyle
Shelly_Marsh wrote: 11 Nov 2016, 13:12
Pretty simple. When you're done with your voxel editing, go up to the top-right corner of the voxel tools manager and click on the "...", then click on "Convert voxels to elements (atlas)"
After that you should be good to go!
Posted: 11 Nov 2016, 19:12
If you have any question on what's the difference between two ways of converting voxels to elements, just ask.
Posted: 12 Nov 2016, 07:21
by patcotts
Sphax wrote: 11 Nov 2016, 19:12
I'd actually like to know. Since I'm still having some issues applying exported textures in game.
Posted: 12 Nov 2016, 07:46
by patcotts
Scratch that I figured it out, but I'm still curious. What is the difference.
Re: New voxel to Element funtion [Solved]
Posted: 12 Nov 2016, 09:01
Convert to elements (palette) creates one element per color when possible. The resulting texturing is super small (directly depends on number of colors used in voxel model).
> It can be nice for small models because it would not have much elements and still use tiny texture. Small texture = less space in RAM.
Convert to elements (atlas) is actually calculating a texture for each face of each elements. Each element will be as big as possible to fit vowel volume.
> It can be nice to avoid creating way too much elements (especially on complex models or models with many colors) but it generates potentially big texture. Few elements = more FPS.
