Texture error when importing .json models
Posted: 09 Nov 2016, 05:34
by AndrealVox
When I import .json models it won't load the textures with it, what do I set the texture file path to in order to automatically read the textures and apply them on import like they did with Cubik Pro? It's a bit of a time issue having to search and load each texture manually.
Re: Texture error when importing .json models
Posted: 09 Nov 2016, 08:20
If you import the JSON from à ResourcePack, Cubik Studio should find textures and import them as well
Posted: 09 Nov 2016, 16:24
by AndrealVox
Sphax wrote: 09 Nov 2016, 08:20
I must be doing something wrong, even when I import the .json from my resource packs folder the textures don't load. Everything always loaded before with Cubik Pro, that's why I'm confused as to why it's not working now. Both textures and .json files are where they have always been lol
Posted: 09 Nov 2016, 18:15
you attach your RP (with only the files with the issue you are talking about) here? Or you can send it to me in PM
Posted: 09 Nov 2016, 19:54
by AndrealVox
Sphax wrote: 09 Nov 2016, 18:15
I will do that.
Posted: 10 Nov 2016, 16:29
by AndrealVox
I sent you a PM, any answers to what the error could be?
I even opened up Cubik Pro imported the .json model and the textures load just fine automatically, tried to do the same thing in Cubik Studio and it can't find the same texture that Pro just did, so what is Studio missing? lol
Posted: 10 Nov 2016, 16:58
I had a look at your model and the only texture which does not load is "items/water_overlay" with label "inside" but it does not load because the texture is actually in "blocks" folder and not "items" folder.
Posted: 10 Nov 2016, 19:32
by AndrealVox
I noticed that and fixed it, although that doesn't help with the fact the Cubik Studio still doesn't load the textures automatically, at all. Maybe I'll make a short video and upload it to youtube showing me importing a model into CubikPro and the textures loading fine, then doing the same steps in CubikStudio with no results. Then maybe you'll be able to see if I'm doing something wrong with CubikStudio that CubikPro just does automatically.
Posted: 10 Nov 2016, 20:15
by AndrealVox
Sphax wrote: 10 Nov 2016, 16:58
I sent you a PM with the youtube link to the video where you can see the error. maybe seeing it will help you better in answering me and understanding my problem. Thanks.
Re: Texture error when importing .json models [Solved]
Posted: 10 Nov 2016, 21:11
I understand your problem but I would like to reproduce to spot where the error is to solve the bug if any.
