How to setup customizable keys
Posted: 22 Feb 2018, 15:17
Since Cubik Studio 2.9 you can set custom keys for the following commands:
  1. Rotate mode : to rotate selection (of elements and/or meshes)
  2. Scale mode : to scale selection
  3. Clone mode : to duplicate selection
  4. Pan view : to move the view with mouse
  5. Focus view : to make the camera look at and turn around point where the mouse cursor is on
How to
For any command listed, you can customize the key(s).
In Tools > Preferences > Advanced, then in the field corresponding to the command you want to customize the key(s), enter the key name you want to use. You can enter up to 4 different keys separated with a comma.
For example for the Alt key, you can enter "LeftAlt" and "RightAlt".
Generic keys
  • Backspace : The backspace key.
  • Delete : The forward delete key.
  • Tab : The tab key.
  • Clear : The Clear key.
  • Return : Return key.
  • Pause : Pause on PC machines.
  • Escape : Escape key.
  • Space : Space key.
  • UpArrow : Up arrow key.
  • DownArrow : Down arrow key.
  • RightArrow : Right arrow key.
  • LeftArrow : Left arrow key.
  • Insert : Insert key key.
  • Home : Home key.
  • End : End key.
  • PageUp : Page up.
  • PageDown : Page down.
  • All letters (A, B, C, ..., Y, Z)
Numbers (alpha and keypad)
  • Alpha0 : The '0' key on the top of the alphanumeric keyboard.
  • Alpha1 : The '1' key on the top of the alphanumeric keyboard.
  • Alpha2 : The '2' key on the top of the alphanumeric keyboard.
  • Alpha3 : The '3' key on the top of the alphanumeric keyboard.
  • Alpha4 : The '4' key on the top of the alphanumeric keyboard.
  • Alpha5 : The '5' key on the top of the alphanumeric keyboard.
  • Alpha6 : The '6' key on the top of the alphanumeric keyboard.
  • Alpha7 : The '7' key on the top of the alphanumeric keyboard.
  • Alpha8 : The '8' key on the top of the alphanumeric keyboard.
  • Alpha9 : The '9' key on the top of the alphanumeric keyboard.
  • Keypad0 : Numeric keypad 0.
  • Keypad1 : Numeric keypad 1.
  • Keypad2 : Numeric keypad 2.
  • Keypad3 : Numeric keypad 3.
  • Keypad4 : Numeric keypad 4.
  • Keypad5 : Numeric keypad 5.
  • Keypad6 : Numeric keypad 6.
  • Keypad7 : Numeric keypad 7.
  • Keypad8 : Numeric keypad 8.
  • Keypad9 : Numeric keypad 9.
  • KeypadPeriod : Numeric keypad '.'.
  • KeypadDivide : Numeric keypad '/'.
  • KeypadMultiply : Numeric keypad '*'.
  • KeypadMinus : Numeric keypad '-'.
  • KeypadPlus : Numeric keypad '+'.
  • KeypadEnter : Numeric keypad enter.
  • KeypadEquals : Numeric keypad '='.
Special keys
  • RightShift : Right shift key.
  • LeftShift : Left shift key.
  • RightControl : Right Control key.
  • LeftControl : Left Control key.
  • RightAlt : Right Alt key.
  • LeftAlt : Left Alt key.
  • LeftCommand : Left Command key.
  • RightCommand : Right Command key.
Mouse buttons
  • Mouse0 : The Left (or primary) mouse button.
  • Mouse1 : Right mouse button (or secondary mouse button).
  • Mouse2 : Middle mouse button (or third button).
  • Mouse3 : Additional (fourth) mouse button.
  • Mouse4 : Additional (fifth) mouse button.
  • Mouse5 : Additional (or sixth) mouse button.
  • Mouse6 : Additional (or seventh) mouse button.
Re: How to setup customizable keys
Posted: 14 Sep 2019, 01:13
by Coolboy1384
Cubik Studio doesn't save the settings once you change them. I changed my rotate to Mouse1 and it doesn't work
