ETA on version 2.9 and Java exporter fixes?  [Solved]
Post by Tango Tek » 25 Jan 2018, 17:42
I know its been mentioned that the java exporter is buggy/broken. Models I export don't show up correctly in game (which I'm guessing is the problem)
Any idea when 2.9 will be out with fixes for it?
Tango Tek
Re: ETA on version 2.9 and Java exporter fixes?
Post by Tango Tek » 26 Jan 2018, 21:15
For what its worth the changes look pretty simple. The Y direction needs to be flipped and there seems to be Z offset being double applied to both rotationPoint and the box offset.
Tango Tek
Re: ETA on version 2.9 and Java exporter fixes?  [Solved]
Post by Sphax » 12 Feb 2018, 17:08
JAVA export should be fixed in 2.9
