How to fix the Cubik Studio window not appearing
Posted: 06 Jan 2018, 19:13
The bug should be fixed in the next release of Cubik Studio, but in the meantime there are a few ways to solve the issue:
Should work for everyone:
  • Try holding Alt whilst the program is opening (white/black screen)
If for whatever reason that does not work for you you can try the following:
Windows:
  • Whilst the program is open select it in the taskbar then press Windows key + an arrow key
  • Whilst the program is open select it in the taskbar and press Alt+Space and select "Maximize" from the menu that should appear in the top left of your screen
  • Go to C:\Users\<user>\AppData\LocalLow\BDcraft\Cubik and edit cubikdata.json so that "windowX" and "windowY" are 0
Linux:
  • Whilst the program is open right click it in the taskbar and select "Maximize"
  • Go to ~/.config/unity3d/BDcraft/Cubik/ and edit cubikdata.json so that "windowX" and "windowY" are 0
Mac:
I'm unsure about Mac as I have no access to one, but I suspect it's very similar to Linux (in the very least you can search for cubikdata.json and edit the variables as stated above).
Re: How to fix the Cubik Studio window not appearing  [Solved]
Posted: 22 Feb 2018, 16:41
Should not happen anymore with Cubik Studio 2.9
