Problems with install
Posted: 13 Dec 2017, 17:36
by Luucc
When i want to install it, it says ''There should be 'CubikStudio_Data'
folder next to the executable''
Re: Problems with install
Posted: 30 Dec 2017, 17:33
by CaptainGalax
The CubikStudio.exe should be in the same Path as the CubikStudio_Data folder;
It's standard on Unity.
Re: Problems with install [Solved]
Posted: 19 Jan 2018, 10:49
Be sure to extract CubikUpdater in a folder dedicated to Cubik (anywhere you want), then install Cubik and don't move files inside that folder!
You can however move the Cubik folder anywhere you want without any problem (Cubik does not use Windows or MacOS installer with references to uninstaller anywhere outside that folder).
