Page 1 of 2
Saved .cubik doesn't retain texture when converted to elements
Posted: 05 Nov 2016, 22:15
by RootPC
Re: Saved .cubik doesn't retain texture when converted to elements
Posted: 05 Nov 2016, 23:28
by Rob
select all elements and apply loaded texture again?
Posted: 05 Nov 2016, 23:35
by RootPC
Rob wrote: 05 Nov 2016, 23:28
Problem is, is that there is no loaded texture from my end. Basically my process is:
Load OBJ with textures provided, convert to voxels (that's the point where I saved the dragon), save to .cubik, load saved .cubik, convert to elements (which is where the texture goes black).
Also, if I do it the way you suggest, I will have applied one texture to the whole dragon, when I have multiple textures for specific areas of the dragon (detailed)
Posted: 05 Nov 2016, 23:44
by Profyle
RootPC wrote: 05 Nov 2016, 23:35
At the moment, all I can suggest for you is to make those multiple textures fit into one big texture.
Posted: 05 Nov 2016, 23:46
by Rob
multiple texture aren't supported yet i believe... so yeh try 1 big texture...
Posted: 06 Nov 2016, 00:32
by RootPC
Normally if you convert OBJ to voxels to elements straight away, it'll save the textures in one png and there'll be only the one bug posted in another thread, but from .cubik to elements it breaks before saving the textures and makes the png black
Posted: 06 Nov 2016, 10:28
This is a bug. Loaded .cubik format do not load color palette properly and so converting to elements just bring black texture atlas. This will be fixed in next update.
Re: Saved .cubik doesn't retain texture when converted to elements [Solved]
Posted: 06 Nov 2016, 15:37
Fixed in next update
Posted: 06 Nov 2016, 18:00
by thedestruc7i0n
Can't wait for this bug to get fixed... Been bothering me for a while...
Posted: 08 Nov 2016, 03:35
by GlobbyLikesSlime
Noob question, but has the update come out yet because I absolutely hate this bug.
