how do i change the elements material from an atlas to a palette for a build that made from elements?
Posted: 22 Nov 2017, 00:46
by CptJackSwagg3r
hello, so i had a guy make a vehicle and it looks super cool but right now were trying to figure out how to turn the atlas he made(attachment named "ghost") into a simple palette (ghost2)
Re: how do i change the elements material from an atlas to a palette for a build that made from elements? [Solved]
Posted: 28 Nov 2017, 10:43
You can only get "palette" texture when converting voxels to elements. You can't do that from elements. You should open a backup of your voxels model to convert it back to elements using palette method.
If you want a smaller texture, you can also try to optimize the model (optimize button with yellow bolt icon) and then regenerate the texture atlas with the Textures List panel.
