How abought a way to export models as ". schematic". Tthe program matches each voxel color with a minecraft block and generates a MCedit file that you can put in your world.
You would be able to select which blocks you want and size of the construction.
Export models as ". schematic" [Solved]
Re: Export models as ". schematic" [Solved]
That has already been suggested and has been added for 2.9
Could you then maybe think about adding also support for the blueprint format?
(A more mod friendly version of schematics http://dark-roleplay.net/other/blueprint_format.php)
- MasterClaus
- Likes: 1 x | 2 x
