obj to json problem
Posted: 05 Nov 2016, 09:49
by theismarius
hi, i imported an obj model with its texture to cubik studio, then i voxelized it, and the textures still be there and all fine but no elements appear, either way, i tried to export it to json but of couse it didnt work, anyone knows what is the problem?
Re: obj to json problem
Posted: 05 Nov 2016, 13:19
by Rob
did you converted the voxels to elements?
Posted: 05 Nov 2016, 13:37
by theismarius
how?
Posted: 05 Nov 2016, 13:38
by theismarius
a ok but the original textures then dont work
Posted: 05 Nov 2016, 13:59
by Rob
Yes that happens indeed, try to load the new textures and then apply them to the elements.
When your texture is imported, then click a element and press ctrl+a, that way you select all elements...
or hold ctr+click element for individual element selections...
When those are selected apply your texture and adjust UV if needed
Posted: 05 Nov 2016, 14:03
by theismarius
but the original texture or make a new one with the pallet?
Posted: 05 Nov 2016, 14:13
by Rob
you can try the Original one, but you'll need to apply the correct UV area to the elements...
The pallet should be applied already if i'm not mistaking.
Posted: 05 Nov 2016, 14:15
by theismarius
Posted: 05 Nov 2016, 14:26
by Rob
you should be able to, i'm not too sure how to do this the easiest way, Also did it generate a voxel texture pallet?
if so, try to convert it to elements first.
Re: obj to json problem [Solved]
Posted: 06 Nov 2016, 22:16
theismarius wrote: 05 Nov 2016, 13:38
This is fixed in next update
