Username or password incorrect even tho its correct
Posted: 19 Aug 2017, 16:53
by realkhubeb
Guys when i purchased cubik it said i had to check my email and activate the acc so i click on the link in the email and it said login and register so i clicked on register i registered my acc and then it said to login right after that and i tries to login with the acc i registered it said 'username or password is wrong' even tho it was right and i even did forgot password and i changed the password and then i tried it still said incorrect i am 100% sure i am correct plz help
Re: Username or password incorrect even tho its correct
Posted: 19 Aug 2017, 17:05
Seems unlikely you're 100% correct if it's not working. You'd be very special to be the only person who can't login (even though you obviously can, because you logged in on this account to post...).
What is the username of your other account?
Posted: 19 Aug 2017, 19:11
by realkhubeb
In the sense i couldn't log in but now i can but when i go to download tab and when i login there with this same acc it says my password and username is wrong its kinda hard to explaib
Re: Username or password incorrect even tho its correct  [Solved]
Posted: 19 Aug 2017, 19:51
The forum and main site use the same login system and account system.
If you can login on the forum you can (and are already) logged in on the Download page.
You just need to follow your activation link again and enter your password.
Posted: 20 Aug 2017, 04:09
by realkhubeb
Ok it is working now but i opend my email from my phine to see if its working or not it was but when i went to my pc it says the key has already beem activated plz help
Posted: 20 Aug 2017, 06:28
by realkhubeb
I took a screen shot of the serial key i havw the receipt can u dm on twitter so i can explain better plz ill show all the proof that i bought this and it will be much easier to explain it there
Posted: 20 Aug 2017, 09:22
It appears you have activated your key.
Go to the Download page and get the software.
