Minecraft don't accept textures
Posted: 04 Nov 2016, 20:04
by weisnicht2002
I did a stone sword model with the voxel tool, converted it to elements and exported it with the texture to minecraft. In minecraft I see the model but the texture isn't on it. Instead there is the purple /black texture. Can somebody help me to get the right texture?
Re: Minecraft don't accept textures
Posted: 06 Nov 2016, 00:12
by Profyle
weisnicht2002 wrote: ↑04 Nov 2016, 20:04
Because the texture either isn't in the right place / was renamed.
Posted: 06 Nov 2016, 12:06
by weisnicht2002
It is in the right place and It has the right name.
Posted: 06 Nov 2016, 13:15
What version of MC are you making textures for? Can you provide some JSON, the names of your textures or an example resourcepack? Have you checked Minecraft's log (you can enable it via your MC profile's settings)?
Just saying you get purple and black textures is basically useless as all anyone can do is guess.
Posted: 07 Nov 2016, 16:36
by D3monPixel
Did you change the setting to export the textures beside the model? You kinda need that and a conversion from the palette to an atlas thing. Then you need to move the color atlas in your textures folder and if you want it renamed be sure to also change the text in the model which tells the elements to use that texture by changing the "atlas" thing at the top to your renamed texture. It's kinda weird and complicated I might say.
