Invisible areas under custom blocks, how to remove?
Posted: 20 Jul 2017, 01:31
by Frostyhobo47
how do you make it so that there aren't invisible areas under a custom block like here
Re: Invisible areas under custom blocks, how to remove?
Posted: 20 Jul 2017, 05:46
by Cryptic
I reccomend making the model bigger, because its smaller than a normal block
Re: Invisible areas under custom blocks, how to remove?  [Solved]
Posted: 20 Jul 2017, 07:03
Only "transparent" blocks can have any kind of 3D model.
Solid blocks can't have a see-through 3D model.
Example:
Logs are solid block
Stairs are transparent blocks
