Add .dds support file (in the .mtl) to .obj importer.  [Solved]
Post by Protoxy » 09 Jul 2017, 21:16
Hi, please add support to load the .dds file (Image) in the .mtl when we import a .obj file.
Example in the .mtl:
http://image.noelshack.com/fichiers/201 ... apture.png
The texture in cubik doesn't want to apply texture, I must convert the .dds to .jpg to apply texture correctly.
Thank you.
Protoxy
Re: Add .dds support file (in the .mtl) to .obj importer.  [Solved]
Post by Sphax » 12 Jul 2017, 19:56
DDS format (DXT1 and DXT5 only) is supported in 2.9 (even for element texture) ;)
