Why when I convert voxels to elements I lose my colors? what is the point in coloring the voxels if you can't use them? I'm sure I'm doing something wrong, but and example or a guide would be helpful.
Because if I have to do it like you use to in cubik pro with texturing every element then it makes studio kinda pointless, please help!
Voxel Colors [Solved]
Voxel Colors
Re: Voxel Colors
Would be nice to always say how you figured out how to solve your issue.
By the way, Im pretty sure you just had to disable the elements tint in Preferences > Display
Re: Voxel Colors
i met this problem too.
i solve it by adding a new voxel in color i use (then remove it)
Re: Voxel Colors
What you are talking about is a bug which has been solved in version 2.1 (if you have 2.0n re-launch Cubik Updater)
