When importing a voxel model made in MagicaVoxel (this could be happening for models made in other programs as well, but I only have MagicaVoxel) the model says it has 0 elements, yet displays the model correctly.
Imgur GIF of what I mean
0 elements when importing model? [Solved]
- ReduxRedstone
Re: 0 elements when importing model?
You've imported a voxel model. If you want to convert voxels to elements, just go in "Voxel" edit mode, then click "..." and select "Convert to elements".
ThanksSphax wrote: 02 Nov 2016, 09:10 You've imported a voxel model. If you want to convert voxels to elements, just go in "Voxel" edit mode, then click "..." and select "Convert to elements".
- ReduxRedstone
