3D Model, don't pull the texture  [Solved]
Post by S1L3NT » 04 May 2022, 15:16
I have a problem, when I import the 3D model, it doesn't add the texture, even after I place them, it still doesn't fit the model, it's still white and no texture.
S1L3NT
Re: 3D Model, don't pull the texture
Post by HanFox » 05 May 2022, 07:52
An example texture pack that has your model and texture in place would be helpful to figure out the issue, otherwise it'll just be random guessing.
Post by S1L3NT » 06 May 2022, 19:35
yes, the 2 items are in the same folder, but it doesn't pull the .img to paint the item, what are the forms of img that the system supports?
S1L3NT
Post by HanFox » 07 May 2022, 06:39
As far as I'm aware Cubik will support the vast majority of basic images. Minecraft only supports PNG though.
Post by S1L3NT » 08 May 2022, 13:53
is there any tutorial that i can see the correct way to import the .obj file along with the img?
S1L3NT
Post by HanFox » 08 May 2022, 18:30
This video has information about importing object files:
Post by S1L3NT » 11 May 2022, 14:09
My problem still continues, I've tried with several models that I have and no success, Can someone help me, I bought the program and I'm not having any results. :cry:
Can I send any .obj model and its .img for you to test?
key002.obj
(42.35 KiB) Downloaded 348 times
S1L3NT
Post by HanFox » 12 May 2022, 06:40
I don't really understand objs too well, but a quick search suggests that they should have an mtl file that accompanies them?
The mtl defines some basic material settings and also a reference to the png with the texture in it.
Post by S1L3NT » 12 May 2022, 15:15
yes i have
S1L3NT
Re: 3D Model, don't pull the texture  [Solved]
Post by S1L3NT » 12 May 2022, 15:33
The problem was solved, Inside the same folder must contain 3 files for importing obj files, being the,
.obj (3D model)
.png (model image)
.mtl (where it contains information on how the .img is applied to the .obj)
S1L3NT
