Option name: Delete confirmation
Option type: Checkbox (on/off)
Enable you to delete without confirmation each time you delete an element
Delete confirmation setting [Solved]
Re: Delete confirmation setting [Solved]
You can do that with Ctrl+Del
Del button will always ask you to confirm the deletion while Ctrl+Del will delete straight away
