Logging into Cubik Pro Legacy Version. [Solved]
Hi. I recently downloaded the released Cubik Pro Legacy, and when i put my email and serial it says that the registration details are wrong. i don't understand what i\m doing wrong so if someone could help that would be appreciated.
Re: Logging into Cubik Pro Legacy Version.
Try re-downloading Cubik Pro legacy. It had a bug preventing the Studio serials from working.
I've just reinstalled it and it gives the same error.Sphax wrote: 14 Feb 2018, 08:26 Try re-downloading Cubik Pro legacy. It had a bug preventing the Studio serials from working.![]()
Ive attempted to use animaker and im getting the same error, could the issue be my Serial?
Animaker has been fixed. It wasn't able to validate the Cubik Studio serial. Just redownload the software and register in with your Cubik Studio serial.Cryptic wrote: 16 Feb 2018, 22:57 Ive attempted to use animaker and im getting the same error, could the issue be my Serial?
For Cubik Pro legacy version, I tested again with a Cubik Studio serial and everything works well. Be sure to use latest Cubik Pro legacy version by redownloading it.
I've just re downloaded both and they give the same error each time i attempt to log in.Sphax wrote: 19 Feb 2018, 08:30Animaker has been fixed. It wasn't able to validate the Cubik Studio serial. Just redownload the software and register in with your Cubik Studio serial.Cryptic wrote: 16 Feb 2018, 22:57 Ive attempted to use animaker and im getting the same error, could the issue be my Serial?
https://imgur.com/aOfu5hY - Error given
Re: Logging into Cubik Pro Legacy Version. [Solved]
The problem is happening for you because you are using Cubik on more computers than authorized.
Can you retry CubikPro or Animaker and let me know if that works now?
it works now, thank you very much!Sphax wrote: 22 Feb 2018, 16:43 The problem is happening for you because you are using Cubik on more computers than authorized.
- BlockCabin
