rotating a model that was converted from an image  [Solved]
Post by Shelly_Marsh » 04 Nov 2016, 15:14
dear people of the help forums i need help because when i try to rotate a model that was converted from an image it is not letting me stand it up. it only rotates half way its for Iron bars BTW
also here is the original image for the Iron bars
iron_bars.png.zip
(30.79 KiB) Downloaded 345 times
Shelly_Marsh
Re: rotating a model that was converted from an image  [Solved]
Post by Sphax » 06 Nov 2016, 22:00
Use the rotate buttons in the "Model" panel on the left of the window. It allows you to rotate the model by 90° ;)
