Function suggestion: Bug fix?  [Solved]
Post by Cookiesnom » 14 Nov 2016, 07:41
Edit mode: Element :element:
Function name: Bug fix?
Function short description:
In the Elements list is has the red text that appears when an element is outside of the 3x3 box.
Example:
But when you rotate the element so that it is inside the 3x3 box.
Example:
Then the text is no longer red, but on export it will give you a purple and black box because it is still outside the 3x3 box.
Cookiesnom
Re: Function suggestion: Bug fix?
Post by Sphax » 15 Nov 2016, 18:04
Hm... This looks like a Minecraft bug more than a Cubik bug. :)
Post by Cookiesnom » 17 Nov 2016, 12:07
would be nice if it was still red, took me a while to figure out what was wrong with my model :), thanks anyways Sphax
Cookiesnom
Re: Function suggestion: Bug fix?  [Solved]
Post by Sphax » 20 Jun 2017, 21:34
Fixed in 2.8
Return to “Suggestions”
