I'm not sure whether is a bug, in the settings,I chose restrict rotations, then i save model, next time open it, need to re-select once and will change the location of the elements (rotation angle no problem)
Is this my problem or bug?
mincraft Rotation
Re: mincraft Rotation
I'm sorry to reply to you now,because not have notificationsSphax wrote: 29 May 2017, 20:21 Do you have a .cubik file on which the error is happening all the time?
I do not have that file right now,but there is another problem,why has chosen restrict rotations, the angle is still wrong?
I have chosen restrict rotations before making this one,then save
next time i open this want to export will display three elements of the angle is not correct,then i re-select restrict rotations to fix it
want export it again,still display have one elements of the angle is not correct,but when i re-select restrict rotations not have change,then i can export
https://drive.google.com/open?id=0B08yg ... 3JGTG16Z0E
This is the same as the previous one
When i want export,its display 15 elements of the angle is not correct,then i re-select restrict rotations not have change anything
https://drive.google.com/open?id=0B08yg ... GIyMEw3Ykk
You are not supposed to disable and enable "Restrict rotations" if you create a 3D models for Minecraft Java Block/Item.
If you disable it that's because you are creating a model for another format than Minecraft Java 3D models (Blocks or Items).
