Key usage reset  [Solved]
Key usage reset
Post by rafradek » 15 Apr 2017, 12:27
I want to move into a new PC, so I would like to have my key uses reset, to avoid further problems.
rafradek
Re: Key usage reset  [Solved]
Post by Sphax » 17 Apr 2017, 09:18
You don't need to ask for a reset even before having a problem. Just move to another PC if you want, use your Serial and Username and see if that works.
Then if that doesn't work, just tell us here. ;)
