Adding an element to selection using left control key [Solved]
For some reason only right control key can be used to select multiple objects. Why can't both keys do the same thing (At least for the element list)?
Re: Adding an element to selection using left control key [Solved]
Currently Right Ctrl and Right Shift only are usable to modify selection.
Left Ctrl and Left Shift are used for the rotation and scale
That might be modified/improved in a future update
